[postgis-tickets] [PostGIS] #2423: [REGRESSION] ST_LineToCurve gets semicircle wrong
PostGIS trac at osgeo.org
Mon Aug 12 01:48:50 PDT 2013
 Reporter:  strk     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:  PostGIS 2.0.4
Component:  postgis  |     Version:  2.0.x
 Keywords:  curves   |
Comment(by strk):
 Beside breaking the arc at the appropriate place (when angle between edges
 changes drastically) I think we should also avoid to define circles with a
 single curve, because such a curve would effectively be only defined by 2
 points (as first and last would be the same) thus allowing for infinite
 arcs. When a circle is detected (which would be wrong, in this case) the
 code should produce an output composed by two semicircle curves (but this
 is probably the topic for another ticket).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2423#comment:3>
