[postgis-tickets] [PostGIS] #2423: [REGRESSION] ST_LineToCurve gets semicircle wrong
trac at osgeo.org
Mon Aug 12 01:51:53 PDT 2013
Reporter: strk | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.4
Component: postgis | Version: 2.0.x
Keywords: curves |
Comment(by strk):
Or, by convention, we could assume that the control point of a full circle
must always be on the other side of the diameter starting from the
first/last point of the curve. In this case the control point should then
be 10,0 rather than 0,10.
The actual output:
CURVEPOLYGON(CIRCULARSTRING(-10 0,-3.73640463187386e-14 10,-10 0))
The input:
st_intersection(st_buffer(st_point(0,0),10),'POLYGON((-10 0,10 0,10 10,-10
10,-10 0))')
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2423#comment:4>
