[postgis-tickets] [PostGIS] #2454: [raster] ST_PixelAsPolygons does not obey exclude_nodata_value=TRUE
trac at osgeo.org
Fri Aug 30 06:46:04 PDT 2013
Reporter: alfred | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.1
Component: raster | Version: 2.1.x
Keywords: |
Comment(by dustymugs):
When '''exclude_nodata_value''' = true, the value for NODATA pixels are
returned as NULL. When '''exclude_nodata_value''' = false, the value for
NODATA pixels are returned as the number designated the NODATA value.
You can get rid of those NULL values by adding a where clause...
SELECT (gv).x, (gv).y, (gv).val, ST_AsText((gv).geom) geom
FROM (SELECT ST_PixelAsPolygons(
ST_SetValue(ST_SetValue(ST_AddBand(ST_MakeEmptyRaster(2,
2, 0, 0, 0.001, -0.001, 0.001, 0.001, 4269),
'8BUI'::text, 1, 0),
2, 2, 10),
1, 1, NULL), 1, true
) gv
) foo
WHERE (gv).val IS NOT NULL
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2454#comment:1>
