[postgis-tickets] [PostGIS] #2454: [raster] ST_PixelAsPolygons does not obey exclude_nodata_value=TRUE
trac at osgeo.org
Fri Aug 30 06:59:30 PDT 2013
Reporter: alfred | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.1
Component: raster | Version: 2.1.x
Keywords: |
Comment(by dustymugs):
Looking at how the behavior changed between 2.0 and 2.1 (the
'''exclude_nodata_value''' parameter was added in 2.1),
ST_PixelAsPolygons() has always returned NULL value for a pixel set to the
NODATA value. This behavior is present before 2.0.
The '''exclude_nodata_value''' parameter was added in 2.1 so that ALL
pixel values would be returned regardless of a pixel being NODATA or not.
If people think that the behavior should be changed so that when
'''exclude_nodata_value''' = true NODATA pixels are not returned, that
change can be made for 2.2.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2454#comment:2>
