[postgis-tickets] [PostGIS] #2456: Documentation update, correct PostGIS tarball version references
trac at osgeo.org
Sat Aug 31 17:02:26 PDT 2013
Reporter: kentr | Owner: robe
Type: task | Status: closed
Priority: high | Milestone: PostGIS 2.1.1
Component: documentation | Version: 2.1.x
Resolution: fixed | Keywords: documentation
Changes (by robe):
* status: new => closed
* resolution: => fixed
Comment:
kentr,
I'm going to close this out since the primary issue of it pointing at old
docs is corrected. I'll also add to the HOW_TO_RELEASE docs to update
this alias link to latest stable. If you feel strongly about changing path
to postgis.net/source, please chime in and I will bring the topic up for
vote.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2456#comment:6>
