[postgis-tickets] [PostGIS] #2456: Documentation update, correct PostGIS tarball version references
PostGIS trac at osgeo.org
Sat Aug 31 17:08:50 PDT 2013
  Reporter:  kentr          |       Owner:  robe
      Type:  task           |      Status:  closed
  Priority:  high           |   Milestone:  PostGIS 2.1.1
 Component:  documentation  |     Version:  2.1.x
Resolution:  fixed          |    Keywords:  documentation
Comment(by kentr):
 > If you feel strongly about changing path to postgis.net/source
 Not at all.  This is your project, and if you prefer direct links then I
 respect that.
 The suggestion only was meant to relieve the need for changing the links
 to the tarballs on every release.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2456#comment:7>
