[postgis-tickets] [PostGIS] #2498: PostgreSQL/PostGIS hangs while creating spatial index
PostGIS trac at osgeo.org
Sun Oct 6 22:31:23 PDT 2013
 Reporter:  wagm     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  medium   |   Milestone:
Component:  postgis  |     Version:  2.1.x
 Keywords:           |
 I have a rather small table (262 rows) with POINT geometry for which I
 want to create a spatial index (The data I used you will find in the
 attached SQL file). When I try to create the spatial index on the geometry
 column the query will run and never end. To only way to cancel this query
 is to restart my computer (restarting just the PostgreSQL server won't
 work). If I delete just a single (arbitrary) row from this table and then
 run the "CREATE INDEX ..." statement the index is created within a few
 milliseconds. I currently have no idea what causes this behavior. I
 discovered the issue when I tried to restore data from a dump file and
 pg_restore would never finish. This happens with PostGIS 2.1 under Windows
 and Linux (64-Bit OS). I have not tested if this issue occurs also using
 PostGIS 2.0.
 Many thanks,
 Michael
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2498>
