[postgis-tickets] [PostGIS] #2502: postgis_full_version() not finding topology if not in search_path
trac at osgeo.org
Tue Oct 8 03:19:16 PDT 2013
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.0.x
Keywords: |
If "topology" schema is not in your search_path, the
"postgis_full_version()" function fails to realize that the topology is
installed.
It is common for "topology" to be not in path when the extension is
initially enabled.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2502>
