[postgis-tickets] [PostGIS] #2489: st_asgml functions not dropped 2.0 to 2.1 upgrade
trac at osgeo.org
Tue Oct 8 06:32:42 PDT 2013
Reporter: kyngchaos | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.1
Component: build/upgrade/install | Version: 2.1.x
Keywords: |
Comment(by robe):
there are a bunch of raster ones I see as well.
I think this is the full list (well upgrading from 2.0.4 to 2.1 I need to
check with lower than 2.0.4 suspect there are some) need to add to the
drop afters. Will do once I can test.
DROP FUNCTION IF EXISTS st_asgml(integer, postgis.geometry, integer,
integer, text);
DROP FUNCTION IF EXISTS st_asgml(integer, postgis.geography, integer,
integer, text);
DROP FUNCTION IF EXISTS _st_asgml(integer, postgis.geometry, integer,
integer, text);
DROP FUNCTION IF EXISTS _st_asgml(integer, postgis.geography, integer,
integer, text);
Raster ones
DROP FUNCTION IF EXISTS _st_aspect4ma(double precision[], text, text[]);
DROP FUNCTION IF EXISTS _st_hillshade4ma(double precision[], text,
text[]);
DROP FUNCTION IF EXISTS _st_mapalgebra4unionfinal1(raster);
DROP FUNCTION IF EXISTS _st_mapalgebra4unionstate(raster, raster,
integer);
DROP FUNCTION IF EXISTS _st_mapalgebra4unionstate(raster, raster);
DROP FUNCTION IF EXISTS _st_mapalgebra4unionstate(raster, raster, text);
DROP FUNCTION IF EXISTS _st_mapalgebra4unionstate(raster, raster, integer,
text);
DROP FUNCTION IF EXISTS _st_mapalgebra4unionstate(raster, raster, text,
text, text, double precision, text, text, text, double precision);
DROP FUNCTION IF EXISTS _st_slope4ma(double precision[], text, text[]);
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2489#comment:4>
