[postgis-tickets] [PostGIS] #2502: postgis_full_version() not finding topology if not in search_path
trac at osgeo.org
Tue Oct 8 14:37:53 PDT 2013
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by robe):
This is clearly a bug and probably one you run into when you are switching
from non-extension to extension install?
It's borderline. I say fix it since its clearly broken and the behavior
of extension vs. non-extension is different which is a big no no already.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2502#comment:2>
