[postgis-tickets] [PostGIS] #2503: ERROR: table "topology" is not a member of the extension being created
trac at osgeo.org
Wed Oct 9 01:27:14 PDT 2013
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone:
Component: build/upgrade/install | Version: 2.1.x
Keywords: extension |
Comment(by strk):
I think one problem is with misuse of CREATE EXTENSION command.
Step 4 works by luck, both steps 4 and 5 are bogus because I'm pretending
to have extension installed (rather than "unpackaged"). Not 100% sure this
is bogus, and that's a second problem: we're not being friendly enough
with the user to tell what's inappropriate call, if so.
Now, is it correct for use to put the pg_extension_config_dump in the
upgrade scripts, rather than only in the unpackaged-to-whatever ?
Also, should we have multiple unpackaged--* scripts, one for each
unpackaged minor version ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2503#comment:3>
