[postgis-tickets] [PostGIS] #2501: EXTENSION in-place upgrade from 2.0 from 2.1 leaves topology procs not upgraded
PostGIS trac at osgeo.org
Wed Oct 9 04:09:49 PDT 2013
upgraded
 Reporter:  zenitram               |       Owner:  strk
     Type:  defect                 |      Status:  assigned
 Priority:  high                   |   Milestone:  PostGIS 2.1.1
Component:  build/upgrade/install  |     Version:  2.1.x
 Keywords:                         |
Comment(by strk):
 Ok I can see that the the problem is indeed bug #2502, in that after the
 upgrade of topology extension from 2.0.3 to 2.1.0 we end up having two
 different versions of "postgis_topology_scripts_installed". One in the
 public schema, and the other in the "topology" schema.
 Up to right after CREATE EXTENSION FROM unpackaged there's a single one,
 and it is in public.
 Running "ALTER EXTENSION postgis_topology UPDATE TO '2.1.0'" create the
 new function under topology and doesn't drop the one in public.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2501#comment:10>
