[postgis-tickets] [PostGIS] #2507: bots failing on dumper-shp.prj No such file
trac at osgeo.org
Thu Oct 10 10:30:10 PDT 2013
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: buildbots | Version: 2.0.x
Keywords: |
this file I see generated on both winnie and debbie, in right temp folder,
but both are registering as can't find the file.
Might be a timing issue, a permissions issue, or the code is checking
default location and lying about the path.
Only thing common about both winnie and debbie is they override the temp
folder
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2507>
