[postgis-tickets] [PostGIS] #2507: failing on dumper-shp.prj No such file regress test
trac at osgeo.org
Fri Oct 11 05:01:58 PDT 2013
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: buildbots | Version: 2.0.x
Keywords: |
Comment(by strk):
Ouch, found the problem. Indeed there's another false negative then, due
to the presence of a .prj file where there shouldn't be one. I'll first
fix that, then will fix the test itself (test is bogus because it uses a
SRID=4326 while only SRID=1 is expected to produce a .prj file).
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2507#comment:5>
