[postgis-tickets] [PostGIS] #2496: St_OffsetCurve bug for Geometry with duplicated points
trac at osgeo.org
Mon Oct 14 02:45:57 PDT 2013
Reporter: francob | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.5
Component: postgis | Version: 2.0.x
Keywords: st_offsetcurve offset repeated points |
Comment(by francob):
Hi.
I update my system to
"POSTGIS="2.1.0 r11822" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.7.1, 23
September 2009"
Now
select st_astext(st_offsetcurve('LINESTRING(0 0, 0 0, 5 0, 5 0, 10
0)'::geometry,10))
doesn't crash.
Now st_offsetcurve works with all geometry where st_isisimple='t'
You think that can be considered a bug if st_offsetcurve doesn't work with
geometry like this
(st_issimple return false)
geom:
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
SELECT st_offsetcurve (geom,10)
give this error
GEOSOffsetCurve: TopologyException: assigned depths do not match at
1512895.9378084207 5033276.5839699283
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2496#comment:6>
