[postgis-tickets] [PostGIS] #2485: [raster]: raster constraints prevent raster data from restoring
trac at osgeo.org
Mon Oct 14 17:18:31 PDT 2013
Reporter: rdunklau | Owner: dustymugs
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.5
Component: raster | Version: trunk
Keywords: |
Comment(by robe):
rdunklau,
I think embedding the sql call will unfortunately cause other problems, so
best bet is probably making these completely C calls. That will take some
time so probably can't be done for 2.1.1 (probably 2.1.2)
If you are using PostgreSQL 9.2+ you can use the new pg_dump that allows
you to separate
the data structure, data load calls. As I recall I think it also allows
you do restore separate sections. I think the search path is only
overwritten in the table structure create steps so if you restore the
structure first, set your database search paths and then restore the data,
it will work fine.
I'll try to document this, but sadly is only a fix for 9.2+ users
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2485#comment:20>
