[postgis-tickets] [PostGIS] #2485: [raster]: raster constraints prevent raster data from restoring
trac at osgeo.org
Mon Oct 14 17:42:04 PDT 2013
Reporter: rdunklau | Owner: dustymugs
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.0.5
Component: raster | Version: trunk
Keywords: |
Comment(by robe):
The only (not a lot of steps solution) I can think of is to install
postgis in pg_catalog.
I've often toyed with that idea but never checked to see if it poses other
problems. I'm beginning to like that solution.
1) Tucks those 1000s of functions away from sight
2) Gets around this issue of functions not accessible during restore since
pg_catalog is ALWAYs part of search path
3) Not having to set search_path if you choose to have a schema for
postgis functions
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2485#comment:22>
