[postgis-tickets] [PostGIS] #2507: failing on dumper-shp.prj No such file regress test
trac at osgeo.org
Tue Oct 15 07:57:10 PDT 2013
Reporter: robe | Owner: robe
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.2.0
Component: buildbots | Version: 2.0.x
Resolution: | Keywords:
Changes (by strk):
* status: closed => reopened
* resolution: fixed =>
Comment:
I guess it could be about reuse: first file is created with read-only
perms (umask?) and second one is forbidden to override. I'll try using
different names for different (sub) tests .
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2507#comment:14>
