[postgis-tickets] [PostGIS] #2513: postgis Updation from 2.0 to 2.1
trac at osgeo.org
Mon Oct 21 15:34:12 PDT 2013
Reporter: rsirimalla | Owner: pramsey
Type: defect | Status: closed
Priority: high | Milestone: PostGIS 2.1.1
Component: postgis | Version: 2.0.x
Resolution: duplicate | Keywords: PostGIS; cannot access
Comment(by robe):
One question before I dismiss this as a duplicate -- did you get an error
after doing
ALTER EXTENSION postgis ...
From the sounds of this,it sounds like you simply migrated 9.1 to 9.2
without upgrading your database as well.
Your database would still be in 2.0. What you should have done is upgraded
your 9.1 instance to 2.1 and then migrated over. Or install 2.0 on 9.2
and then upgraded your db to 2.1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2513#comment:2>
