[postgis-tickets] [PostGIS] #2510: Remove postgis_major_version_check from postgis_upgrade_20_21.sql
trac at osgeo.org
Thu Oct 24 09:13:56 PDT 2013
Reporter: pramsey | Owner: pramsey
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.1.1
Component: postgis | Version: 2.1.x
Keywords: |
Comment(by strk):
The revision above keeps trying with postgis_lib_version() but catches an
exception by reverting to use of postgis_script_version(). If you like the
resulting experience it'll have to be backported to 2.1 and 2.0 branches.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2510#comment:6>
