[postgis-tickets] [PostGIS] #2515: change licensing to GPL2+
trac at osgeo.org
Sat Oct 26 10:51:36 PDT 2013
Reporter: strk | Owner: pramsey
Type: task | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.0.x
Keywords: |
Comment(by strk):
I've run a grep for copyright holders in the whole code base.
Here it is:
Individuals:
Andrea Peri <aperi2007 at gmail.com>
Paul Ramsey <pramsey at cleverelephant.ca>
Regina Obe <lr at pcorp.us>
Sandro Santilli <strk at keybit.net>
Mark Cave-Ayland <mark.cave-ayland at siriusit.co.uk>
Olivier Courtin <olivier.courtin at oslandia.com>
Nicklas Avén <nicklas.aven at jordogskog.no>
J Smith <dark.panda at gmail.com>
David Skea <David.Skea at gov.bc.ca>
Kashif Rasul <kashif.rasul at gmail.com>
Companies:
Arrival 3D
Corporacion Autonoma Regional de Santander
OpenGeo.org
Oslandia <infos at oslandia.com>
Refractions Research Inc.
Irrelevant:
Thamer Alharbash -- only holds (C) on MIT-like licensed file
OSGeo -- only holds (C) in libpgcommon/common.h, which is 3 include lines
I shall notice that NONE of the copyright headers explicitly specify a
version for the license, but rather point to a COPYING file:
* This is free software; you can redistribute and/or modify it under
* the terms of the GNU General Public Licence. See the COPYING file.
According to the GPLv2, which is what we find in the COPYING file, the
absence of an explicit version means that the work can be distributed with
_any_ version of the GPL licenses.
Here's the pointer:
https://github.com/postgis/postgis/blob/svn-trunk/COPYING#L246
So I believe we don't really need to change license, but also there should
be no problem in releasing a composite work as GPLv3 (ie: there's no
"version 2 only" specification anywhere).
We would need to get permission to make GPLv3 the _minimum_ version
allowed.
But I guess it'll become automatic as time goes by (for SFCGAL dependency
or raster or whatever).
See also #2514
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2515#comment:7>
