[postgis-tickets] [PostGIS] #2878: winnie coughing up blood when trying to build cunit for twkb
trac at osgeo.org
Sun Aug 10 09:12:13 PDT 2014
Reporter: robe | Owner: nicklas
Type: defect | Status: reopened
Priority: blocker | Milestone: PostGIS 2.2.0
Component: postgis | Version: trunk
Resolution: | Keywords:
Comment(by robe):
Hmm that is surprising why such a speed difference. All things I have
read (which granted is not much), say speed improvement is so negligable
not to bother with that optimization. What test are you running with?
Maybe I can test on mingw to see what speed differences are like. Which
gcc compiler are you using? I'm using 4.8.0 and 4.8.1.
The code compiles btw I guess because only lwout_twkb includes varint.h in
normal operation mode. So just the cunit testing part includes twice.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2878#comment:15>
