[postgis-tickets] [PostGIS] #3000: Edge linking does not use index
PostGIS trac at osgeo.org
Mon Dec 29 03:50:46 PST 2014
 Reporter:  strk         |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.2.0
Component:  topology     |     Version:  trunk
 Keywords:  performance  |
Changes (by strk):
 * cc: bjornharrtell (added)
Comment:
 As indexes make database size bigger and slow down insertions/updates (see
 https://github.com/postgis/postgis/pull/30#issuecomment-68251146) an
 alternative would be to seek for the edge to be updated within the set of
 edges that should have been already fetched to check for intersection, or
 use the endpoint nodes indexes. That is, rewriting the update sql query.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3000#comment:2>
