[postgis-tickets] [PostGIS] #3000: Edge linking does not use index
trac at osgeo.org
Mon Dec 29 04:03:09 PST 2014
Reporter: strk | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.2.0
Component: topology | Version: trunk
Keywords: performance |
Comment(by strk):
The SQL query is in the ST_ModEdgeSplit function (and similar one appears
in ST_NewEdgeSplit). This means the penalty only occurs on edge splitting,
which should only happen when adding an edge which intersects an existing
one.
Hint for testing: use ST_ModEdgeSplit and ST_ModEdgeHeal iteratively while
changing query/indexes.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3000#comment:3>
