[postgis-tickets] [PostGIS] #3000: Edge linking does not use index
PostGIS trac at osgeo.org
Mon Dec 29 14:10:36 PST 2014
 Reporter:  strk         |       Owner:  strk
     Type:  enhancement  |      Status:  new
 Priority:  medium       |   Milestone:  PostGIS 2.2.0
Component:  topology     |     Version:  trunk
 Keywords:  performance  |
Comment(by strk):
 This patch modifies the SQL query of ST_ModEdgeSplit and ST_ModEdgeHeal to
 add a filter on start_node and end_node to get the opportunity to use
 existing indexes. Speeds up my syntetic test from 0.4 seconds to 0.064
 seconds (splitting and re-healing an edge in a ~500k edges topo).
  http://strk.keybit.net/tmp/useIndexOnSplitAndHealModEdge.patch
 Björn, could you test it against your use case ? The patch will need to be
 finished to replicate the code in the "NewEdge?" versions of the
 functions.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3000#comment:4>
