[postgis-tickets] [PostGIS] #2560: view xxx depends on function st_union(geometry)
trac at osgeo.org
Sun Feb 23 06:01:15 PST 2014
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.2
Component: build/upgrade/install | Version: 2.1.x
Keywords: |
Comment(by strk):
Ok, I see the problem.
Your 2.1.2dev--2.1.2devnext.sql script _assumes_ that aggregates are
ALWAYS created, while now they are only created IF they need be. And
that's intentional, because the subject of this bug is infact being unable
to upgrade while having views defined taht _depend_ on those aggregates.
So I think the actual fix would be dropping the assumption, which I belive
is built into the call to SELECT
postgis_extension_remove_objects('postgis', 'AGGREGATE');
Similarly all other "drops" for extension should be made version-
dependent.
What's the rationale for extensions NOT using the same scripts used for
extension-less upgrades ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2560#comment:24>
