[postgis-tickets] [PostGIS] #2777: [raster] Huge literal in enforce_max_extent_rast check constraint
trac at osgeo.org
Fri Jul 4 03:00:13 PDT 2014
Reporter: strk | Owner: dustymugs
Type: defect | Status: new
Priority: medium | Milestone:
Component: raster | Version: trunk
Keywords: |
Comment(by strk):
Robe: do you see issues with changing the enforce_max_extent_rast
parameter to the envelope ?
The documentation for raster_columns says: "extent This is the extent of
all the raster rows in your raster set." so I'd have it computed using
ST_Extent(raster) -- which does not exist, see #1662. I guess
ST_Extent(rast::geometry) is the closest one, is that good enough for the
sake of raster_columns ?
Sorry if I insist on this ticket but whenever I have to look at a
raster_columns entry I cant because the "extent" field fills up the whole
screen... :/
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2777#comment:10>
