[postgis-tickets] [PostGIS] #2812: [raster] ST_Band that takes delimeter doesn't accept all characters
trac at osgeo.org
Fri Jul 4 21:30:05 PDT 2014
Reporter: robe | Owner: dustymugs
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.2.0
Component: raster | Version: trunk
Keywords: |
Description changed by robe:
Old description:
> As noted in #2180 we should remove this function or fix it to be less
> restrictive.
> In revising the docs, I discoveed I can not do this:
> ST_Band(rast,'1|2|3', '|')
> Which is my next favorite delimeter next to the default ','. The reason
> is because the function is defined like this:
> SELECT st_band($1, regexp_split_to_array(regexp_replace($2,
> '[[:space:]]', '', 'g'), $3)::int[])
> So use of any kind of white space or regular expression key character is
> disallowed. We should clean this up a bit or just deprecate this
> function.
> As stated why anyone would want to change the delimeter seems spurious
> and having an additonal function just so I can type '1,2,3' instead of
> the slightly longer {{{'{1,2,3}'::int[]}} I don't think is worth it.
New description:
As noted in #2180 we should deprecate this function or fix it to be less
restrictive.
SELECT st_band($1, regexp_split_to_array(regexp_replace($2, '[[:space:]]',
function.
As stated why anyone would want to change the delimeter seems spurious and
having an additonal function just so I can type '1,2,3' instead of the
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2812#comment:1>
