[postgis-tickets] [PostGIS] #2812: [raster] ST_Band that takes delimeter doesn't accept all characters
PostGIS trac at osgeo.org
Fri Jul 4 21:29:42 PDT 2014
 Reporter:  robe    |       Owner:  dustymugs
     Type:  defect  |      Status:  new
 Priority:  low     |   Milestone:  PostGIS 2.2.0
Component:  raster  |     Version:  trunk
 Keywords:          |
 As noted in #2180 we should remove this function or fix it to be less
 restrictive.
 In revising the docs, I discoveed I can not do this:
 ST_Band(rast,'1|2|3', '|')
 Which is my next favorite delimeter next to the default ','.  The reason
 is because the function is defined like this:
 SELECT st_band($1, regexp_split_to_array(regexp_replace($2, '[[:space:]]',
 '', 'g'), $3)::int[])
 So use of any kind of white space or regular expression key character is
 disallowed.  We should clean this up a bit or just deprecate this
 function.
 As stated why anyone would want to change the delimeter seems spurious and
 having an additonal function just so I can type '1,2,3' instead of the
 slightly longer  {{{'{1,2,3}'::int[]}} I don't think is worth it.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2812>
