[postgis-tickets] [PostGIS] #2802: [raster] ST_MapAlgebra checks callbacks parameters but not return type
trac at osgeo.org
Mon Jul 7 00:42:58 PDT 2014
Reporter: strk | Owner: dustymugs
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 2.1.4
Component: raster | Version: 2.1.x
Resolution: fixed | Keywords: history
Comment(by strk):
Great, thanks!
nitpicking:
the error printed on returning a SET still says you need to return a
"double precision", while if you return a "text" (for example) the error
tells you that also int,smallint and float4 are accepted.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2802#comment:6>
