[postgis-tickets] [PostGIS] #2825: ST_Intersection broken with Z coordinates
trac at osgeo.org
Mon Jul 7 10:53:04 PDT 2014
Reporter: TBL | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.4
Component: postgis | Version: 2.1.x
Keywords: |
Comment(by TBL):
Sorry, I fucked up the example. Try this one:
with linestring as (
select st_makeline(
(select
st_setsrid(st_makeline(st_makepoint((a-400)/20.0,(a-400)/20.0,a)),4326)
from generate_series(0,800) as a),
(select
st_setsrid(st_makeline(st_makepoint(-(a-1200)/20.0,-(a-1200)/20.0,a)),4326)
from generate_series(801,1600) as a)
) as geom
polygon as (select ST_GeomFromText('POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))',
4326) as geom)
select st_astext(st_intersection(linestring.geom, polygon.geom)) from
linestring, polygon
Expected output would be
MULTILINESTRING Z ((0 0 400, 0.05 0.05 401, [...], 0.95 0.95 419, 1 1
420),
(1 1 1080, 0.95 0.95 1181, [...], 0.05 0.05 1199, 0 0
1200))
instead I get
MULTILINESTRING Z ((0 0 800,0.05 0.05 800),(0.05 0.05 800,0.1 0.1
800),(0.1 0.1 800,0.15 0.15 800),(0.15 0.15 800,0.2 0.2 800),(0.2 0.2
800,0.25 0.25 800),(0.25 0.25 800,0.3 0.3 800),(0.3 0.3 800,0.35 0.35
800),(0.35 0.35 800,0.4 0.4 800),(0.4 0.4 800,0.45 (...)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2825#comment:4>
