[postgis-tickets] [PostGIS] #2825: ST_Intersection broken with Z coordinates
trac at osgeo.org
Mon Jul 7 10:20:26 PDT 2014
Reporter: TBL | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.4
Component: postgis | Version: 2.1.x
Keywords: |
Comment(by pramsey):
Since I don't have your exact input line, I cannot duplicate, but building
a regular line programmatically, I'm not seeing the same result:
with linestring as (
select
st_setsrid(st_makeline(st_makepoint((a-5000)/1000.0,(a-5000)/1000.0,a)),4326)
as geom from generate_series(0,10000) as a
polygon as (
select ST_GeomFromText('POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))', 4326) as
geom)
select st_astext(st_intersection(linestring.geom, polygon.geom)) from
linestring, polygon
POSTGIS="2.1.4dev r12671" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0,
6 March 2012" LIBXML="2.9.0" LIBJSON="UNKNOWN"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2825#comment:3>
