[postgis-tickets] [PostGIS] #2825: ST_Intersection broken with Z coordinates
trac at osgeo.org
Mon Jul 7 14:56:14 PDT 2014
Reporter: TBL | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.4
Component: documentation | Version: 2.1.x
Resolution: | Keywords:
Comment(by robe):
I think this is sorta already resulting in expected behavior if you have
sfcgal support.
Just for example:
set postgis.backend = sfcgal;
with linestring as (
select st_makeline(
(select
st_setsrid(st_makeline(st_makepoint((a-400)/20.0,(a-400)/20.0,a)),4326)
from generate_series(0,800) as a),
(select
st_setsrid(st_makeline(st_makepoint(-(a-1200)/20.0,-(a-1200)/20.0,a)),4326)
from generate_series(801,1600) as a)
) as geom
polygon as (select ST_GeomFromText('POLYGON((0 0, 0 1, 1 1, 1 0, 0 0))',
4326) as geom)
select st_astext(st_intersection(linestring.geom, polygon.geom)) from
linestring, polygon
output is 2D as many people would expect from a 2D function:
MULTILINESTRING((0.05 0.05,0 0),(0.1 0.1,0.05 0.05),(0.15 0.15,0.1
0.1),(0.2 0.2,0.15 0.15),(0.25 0.25,0.2 0.2),(0.3 0.3,0.25 0.25),(0.35
0.35,0.3 0.3),(0.4 0.4,0.35 0.35),(0.45 0.45,0.4 0.4),(0.5 0.5,0.45
0.45),(0.55 0.55,0.5 0.5),(0.6 0.6,0.55 0.55),(0.65 0.65,0.6 0.6),(0.7
0.7,0.65 0.65),(0.75 0.75,0.7 0.7),(0.8 0.8,0.75 0.75),(0.85 0.85,0.8
0.8),(0.9 0.9,0.85 0.85),(0.95 0.95,0.9 0.9),(1 1,0.95 0.95))
now if I use the ST_3DIntersection
set postgis.backend=sfcgal
select st_makeline(
(select
(select
) as geom
4326) as geom)
select st_astext(st_3dintersection(linestring.geom, polygon.geom)),
ST_3DIntersects(linestring.geom, polygon.geom) from linestring, polygon
I get
st_astext | st_3dintersects
GEOMETRYCOLLECTION EMPTY | f
I tried swapping out change
set postgis.backend = geos;
and both the built in native ST_3DIntersects agrees that these don't
intersect.
Now if I take a slightly modified that should intersect it does
select st_makeline(
st_geomfromtext('LINESTRING Z (-1 -1 0,-0.5 -0.5 1,0 0 2,0.5 0.5 3,1 1
4,1.5 1.5 5)', 4326),
st_geomfromtext('LINESTRING Z (2 2 6,1.5 1.5 7,1 1 8,0.5 0.5 8,0 0
10)', 4326)
) as geom
polygon as (select ST_GeomFromText('POLYGON((0 0 8, 0 1 8, 1 1 8, 1 0 8, 0
0 8))', 4326) as geom)
select st_astext(st_3dintersection(linestring.geom, polygon.geom)) from
linestring, polygon;
-- output is --
LINESTRING Z (1 1 8,0.5 0.5 8)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2825#comment:12>
