[postgis-tickets] [PostGIS] #2825: ST_Intersection broken with Z coordinates
PostGIS trac at osgeo.org
Mon Jul 7 15:38:21 PDT 2014
  Reporter:  TBL            |       Owner:  robe
      Type:  defect         |      Status:  new
  Priority:  medium         |   Milestone:  PostGIS 2.1.4
 Component:  documentation  |     Version:  2.1.x
Resolution:                 |    Keywords:
Comment(by robe):
 I have put a caution on the ST_Intersection function that is does some
 sort of averaging of Z coordinate and also added sfcgal behavior (for both
 ST_Intersection and ST_3DIntersection) for comparison.  Done at r12753.
 I think it needs more work so I'll leave this ticket open.
 Once debbie is done building doc, you can see changes here:
 http://postgis.net/docs/manual-dev/ST_Intersection.html
 and
 here:
 http://postgis.net/docs/manual-dev/ST_3DIntersection.html
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2825#comment:13>
