[postgis-tickets] [PostGIS] #2836: Receiving ERROR: ExteriorRing: geom is not a polygon with ST_ConcaveHull
PostGIS trac at osgeo.org
Fri Jul 11 08:02:49 PDT 2014
 Reporter:  cumminsjp  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:
Component:  postgis    |     Version:  2.0.x
 Keywords:             |
 I am receiving this error:
 ********** Error **********
 SQL state: XX000
 Context: PL/pgSQL function st_concavehull(geometry,double
 precision,boolean) line 67 at assignment
 when using a target_percent below 0.99.
 I originally posted this question on gis.se because I wasn't sure if it
 was user error or not (still wouldn't rule it out):
 http://gis.stackexchange.com/questions/106854/is-this-correct-behavior-
 for-st-concavehull-postgis
 PostgreSQL 9.2.2, compiled by Visual C++ build 1600, 64-bit
 POSTGIS="2.0.4" GEOS="3.4.2-CAPI-1.8.2 r0" PROJ="Rel. 4.8.0, 6 March 2012"
 GDAL="GDAL 1.10.0, released 2013/04/24" LIBXML="2.7.8" LIBJSON="UNKNOWN"
 (core procs from "2.0.4" need upgrade) RASTER (raster procs from "2.0.4"
 need upgrade)
 I'll attach an export of the table.
 I will say that as I was creating test tables from the large table and
 retesting the query, I was able to successfully to run st_concavehull.  I
 wouldn't have thought that it would have changed what is passed to
 st_concavehull(ST_Collect(.
 with concavePolys as
         select id ,  st_concavehull(ST_Collect(vx), 0.90) concaveHullPoly
         from (
          SELECT  vertex_point vx, id
           FROM public.postgis_concavehull_bugdata1
         union
         SELECT  comparison_vertex_point vx, id
           ) t
           group  by id
           having ST_NPoints (ST_Collect(vx)) > 3
 select * from concavePolys
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2836>
