[postgis-tickets] [PostGIS] #2847: ST_DISTANCE between geography points incorrect
trac at osgeo.org
Fri Jul 18 14:46:41 PDT 2014
Reporter: rotten | Owner: pramsey
Type: defect | Status: new
Priority: high | Milestone:
Component: postgis | Version: 2.1.x
Keywords: |
It appears that ST_DISTANCE is computing distances incorrectly between
geographic points, at least in the version I have (below).
Consider this query which compares the distance between my office and a
nearby pub, versus my office and a nearby baseball stadium:
select
ST_DISTANCE(st_geographyfromtext('POINT(39.982708 -83.008314)'),
st_geographyfromtext('POINT(39.983736
-83.014097)')) as "office to harrisons",
st_geographyfromtext('POINT(39.968347 -83.010781)'))
as "office to clippers"
office to harrisons office to clippers
645.98070299200003300 337.65466923299999300
When I measure these with a ruler in Google Earth I get about 500 meters
for the first one and about 1580 meters for the second one.
I've tried this with spheroid == false, and while the actual measurements
are slightly different they are incorrect as well.
I also tried explicitly setting the SRID. That didn't really change
anything.
I searched the tickets and did not see this particular issue called out,
although there appear to be a recently fixed, related ticket with
ST_DISTANCE and geography polygons, but that was a few releases ago...
This has thrown off a whole bunch of calculations I've been running.
Everything looked good until we actually mapped some of the points today
and realized the distances were wacky. :-( .
select PostGIS_full_version();
POSTGIS="2.1.3 r12547" GEOS="3.4.2-CAPI-1.8.2 r3921" PROJ="Rel. 4.8.0, 6
March 2012" GDAL="GDAL 1.9.2, released 2012/10/08" LIBXML="2.7.8"
LIBJSON="UNKNOWN" RASTER
select version();
PostgreSQL 9.3.2 on x86_64-unknown-linux-gnu, compiled by gcc
(Ubuntu/Linaro 4.6.3-1ubuntu5) 4.6.3, 64-bit
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2847>
