[postgis-tickets] [PostGIS] #2851: [raster] regress failing on PostGIS 2.2 for winnie for regress_index
trac at osgeo.org
Mon Jul 21 12:11:41 PDT 2014
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: buildbots | Version: trunk
Keywords: |
This is on:
PostgreSQL 9.3.4, compiled by Visual C++ build 1600, 64-bit
Postgis 2.2.0dev
- r12814
- 2014-07-21 17:00:00
scripts 2.2.0dev r12814
GEOS: 3.5.0dev-CAPI-1.9.0 r3989
PROJ: Rel. 4.8.0, 6 March 2012
SFCGAL: 1.0.4
regress_index .. failed (diff expected obtained:
/projects/postgis/tmp/2.2.0dev_pg9.3_geos3.5.0dev_gdal1.11.0w64/test_28_diff)
--- regress_index_expected 2014-07-21 12:57:55 -0400
/projects/postgis/tmp/2.2.0dev_pg9.3_geos3.5.0dev_gdal1.11.0w64/test_28_out
2014-07-21 13:06:49 -0400
Details of diff are:
@@ -5,7 +5,7 @@
3618|POINT(130.447205 131.655289)
7245|POINT(128.10466 130.94133)
3+=5:true
-924+=60:true
+924+=60:false:72
12621+=500:true
50000+=600:true
expr|3+=5:true
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2851>
