[postgis-tickets] [PostGIS] #2851: [raster] regress failing on PostGIS 2.2 on winnied and debbie for regress_index
trac at osgeo.org
Tue Jul 22 00:44:27 PDT 2014
regress_index
Reporter: robe | Owner: strk
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.2.0
Component: raster | Version: trunk
Keywords: |
Comment(by strk):
The failure {{{ +924+=60:false:72 }}} is because ANALYZE takes a random
sample and is evidently taking one with which we get a bigger error (72)
than tolerated (60). I guess the best would be to increase the STATISTICS
target for the test table, what do you think ?
As for XML I guess the code could be made to parse the text EXPLAIN
ANALYZE output, but let's use a different ticket for that, ok ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2851#comment:6>
