[postgis-tickets] [PostGIS] #2851: [raster] regress failing on PostGIS 2.2 on winnied and debbie for regress_index
PostGIS trac at osgeo.org
Mon Jul 21 12:21:55 PDT 2014
regress_index
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  raster   |     Version:  trunk
 Keywords:           |
Comment(by robe):
 Actually I just realized for debbie the unsupported XML feature is because
 I didn't compile PostgreSQL with XML support.  Debbie is testing the EDB
 packaged one which does have XML support.  I guess I can recompile with
 XML support.  Then again I'm not sure if all folks just compiling PostGIS
 will compile against a PostgreSQL with xml support.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2851#comment:5>
