[postgis-tickets] [PostGIS] #2851: [raster] regress failing on PostGIS 2.2 on winnied and debbie for regress_index
PostGIS trac at osgeo.org
Mon Jul 21 12:19:15 PDT 2014
regress_index
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  raster   |     Version:  trunk
 Keywords:           |
Description changed by robe:
Old description:
> This is on:
> PostgreSQL 9.3.4, compiled by Visual C++ build 1600, 64-bit
>   Postgis 2.2.0dev
>  - r12814
>  - 2014-07-21 17:00:00
>   scripts 2.2.0dev r12814
>   GEOS: 3.5.0dev-CAPI-1.9.0 r3989
>   PROJ: Rel. 4.8.0, 6 March 2012
>   SFCGAL: 1.0.4
>  regress_index .. failed (diff expected obtained:
> /projects/postgis/tmp/2.2.0dev_pg9.3_geos3.5.0dev_gdal1.11.0w64/test_28_diff)
> --- regress_index_expected      2014-07-21 12:57:55 -0400
> /projects/postgis/tmp/2.2.0dev_pg9.3_geos3.5.0dev_gdal1.11.0w64/test_28_out
> 2014-07-21 13:06:49 -0400
> Details of diff are:
> @@ -5,7 +5,7 @@
>  3618|POINT(130.447205 131.655289)
>  7245|POINT(128.10466 130.94133)
>  3+=5:true
> -924+=60:true
> +924+=60:false:72
>  12621+=500:true
>  50000+=600:true
>  expr|3+=5:true
New description:
 As of r12813
 This is on:
   Postgis 2.2.0dev
  - r12814
   SFCGAL: 1.0.4
 @@ -5,7 +5,7 @@
  3+=5:true
 -924+=60:true
 +924+=60:false:72
  12621+=500:true
  50000+=600:true
  expr|3+=5:true
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2851#comment:4>
