[postgis-tickets] [PostGIS] #2851: [raster] regress failing on PostGIS 2.2 on winnied and debbie for regress_index (was: [raster] regress failing on PostGIS 2.2 for winnie for regress_index)
PostGIS trac at osgeo.org
Mon Jul 21 12:14:42 PDT 2014
regress_index
 Reporter:  robe     |       Owner:  strk
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  raster   |     Version:  trunk
 Keywords:           |
Comment(by robe):
 Failure on debbie too for some test, though different error:
 Testing:
   /var/lib/jenkins/workspace/postgis/branches/2.2/regress/00-regress-
 install/share/contrib/postgis/postgis_comments.sql
 PostgreSQL 9.2.4 on x86_64-unknown-linux-gnu, compiled by gcc (Debian
 4.4.5-8) 4.4.5, 64-bit
   Postgis 2.2.0dev - r12814 - 2014-07-21 16:42:23
   scripts 2.2.0dev r12814
   GEOS: 3.4.3dev-CAPI-1.8.3 r3982
   PROJ: Rel. 4.7.1, 23 September 2009
 regress_index .. failed (diff expected obtained:
 /var/lib/jenkins/workspace/postgis/tmp/2_2_pg9.2w64/test_28_diff)
 --- regress_index_expected      2014-07-21 09:41:09.000000000 -0700
 +++ /var/lib/jenkins/workspace/postgis/tmp/2_2_pg9.2w64/test_28_out
 2014-07-21 09:43:47.000000000 -0700
 @@ -4,11 +4,5 @@
  2594|POINT(130.504303 126.53112)
  3618|POINT(130.447205 131.655289)
  7245|POINT(128.10466 130.94133)
 -3+=5:true
 -924+=60:true
 -12621+=500:true
 -50000+=600:true
 -expr|3+=5:true
 -expr|924+=60:true
 -expr|12621+=500:true
 -expr|50000+=600:true
 +ERROR:  unsupported XML feature
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2851#comment:3>
