[postgis-tickets] [PostGIS] #2829: [raster] Short-cut ST_Clip when extent fully contains raster extent
trac at osgeo.org
Tue Jul 29 01:32:50 PDT 2014
Reporter: strk | Owner: dustymugs
Type: enhancement | Status: closed
Priority: medium | Milestone: PostGIS 2.1.4
Component: raster | Version: trunk
Resolution: fixed | Keywords: history
Comment(by strk):
Ah, thanks. I thought it was about NODATA values being present in the
raster, rather than passed as parameter. I didn't even know there was a
NODATA parameter (too many overloads :)
Forget the SQL implementation notes as there's no way an ST_Clip call
would be using an index (unlikely to use WHERE ST_Clip...). Having it done
within the C function though should still be faster though. Maybe for
another ticket ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2829#comment:7>
