[postgis-tickets] [PostGIS] #2783: Getting compile error when compiling against json 0.10 in mingw64
PostGIS trac at osgeo.org
Fri Jun 27 07:55:05 PDT 2014
 Reporter:  robe     |       Owner:  pramsey
     Type:  defect   |      Status:  new
 Priority:  blocker  |   Milestone:  PostGIS 2.2.0
Component:  postgis  |     Version:  trunk
 Keywords:           |
Comment(by robe):
 Okay i compared the configure.ac scripts, and that is not what changed
 between 2.1 and 2.2.  Only difference between them is the  a line got
 commented out.
 In 2.1 it's
 AC_MSG_RESULT([CPPFLAGS: $CPPFLAGS])
  In 2.2 it's
 dnl AC_MSG_RESULT([CPPFLAGS: $CPPFLAGS])
 Not sure why someone did that as I would think seeing that variable would
 be useful
 I did find the smoking gun -- it's exactly where the error says.
 These lines were added in 2.2:
 #ifdef HAVE_LIBJSON
 # ifdef HAVE_LIBJSON_C
 #  include <json-c/json.h>
 # else
 #  include <json/json.h>
 # endif
 #endif
 If I remove them my code compiles again.  I'm still puzzled why my json
 0.9 works with these lines and my 0.10 doesn't.  Unless if its something
 to do with the fact that it is static vs. 0.10 being dynamic.
 why did we add these line here?  they don't seem to be needed as far as I
 can tell.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2783#comment:2>
