[postgis-tickets] [PostGIS] #3412: geometry intersects edge on TopoGeo_addLinestring with tolerance 0.001
trac at osgeo.org
Tue Dec 29 03:08:10 PST 2015
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.2.1
Component: topology | Version: 2.0.x
Resolution: | Keywords:
Comment (by strk):
What happens after this step is that the line (now in red) is further
snapped to the existing nodes, which moves it further left, to intersects
with the green.
I guess a solution here could be to improve snapping so that subsequent
snapping operations would not move the line anymore.
This might also be seen as a bug in the GEOS snapping routine.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/3412#comment:6>
