[postgis-tickets] [PostGIS] #3067: Make check fails v 2.1.3
PostGIS trac at osgeo.org
Mon Mar 2 11:13:59 PST 2015
 Reporter:  serbinsh  |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  high      |   Milestone:  PostGIS 2.1.6
Component:  postgis   |     Version:  2.1.x
 Keywords:            |
 Currently, I um unable to run a complete make check on my system:
 ...mpicc -g -O2  -Wall -Wmissing-prototypes
 -I/data/software/geos/3.4.2/include -I/data/software/proj/4.8.0/include
 -I.. -c -o cu_node.o cu_node.c
 -I.. -c -o cu_libgeom.o cu_libgeom.c
 -I.. -c -o cu_split.o cu_split.c
 -I.. -c -o cu_stringbuffer.o cu_stringbuffer.c
 -I.. -c -o cu_triangulate.o cu_triangulate.c
 -I.. -c -o cu_homogenize.o cu_homogenize.c
 -I.. -c -o cu_force_sfs.o cu_force_sfs.c
 -I.. -c -o cu_out_wkt.o cu_out_wkt.c
 -I.. -c -o cu_out_wkb.o cu_out_wkb.c
 -I.. -c -o cu_out_gml.o cu_out_gml.c
 -I.. -c -o cu_out_kml.o cu_out_kml.c
 -I.. -c -o cu_out_geojson.o cu_out_geojson.c
 -I.. -c -o cu_out_svg.o cu_out_svg.c
 -I.. -c -o cu_surface.o cu_surface.c
 -I.. -c -o cu_out_x3d.o cu_out_x3d.c
 -I.. -c -o cu_in_geojson.o cu_in_geojson.c
 -I.. -c -o cu_in_wkb.o cu_in_wkb.c
 -I.. -c -o cu_in_wkt.o cu_in_wkt.c
 cu_in_wkt.c: In function ‘cu_wkt_in’:
 cu_in_wkt.c:54:6: warning: variable ‘rv’ set but not used [-Wunused-but-
 set-variable]
   int rv = 0;
 cu_in_wkt.c: In function ‘test_wkt_in_errlocation’:
 cu_in_wkt.c:332:6: warning: variable ‘rv’ set but not used [-Wunused-but-
 set-variable]
   int rv = 0;
 -I.. -c -o cu_tester.o cu_tester.c
 /bin/sh ../../libtool --mode=link mpicc -g -O2  -Wall -Wmissing-prototypes
 -o cu_tester cu_algorithm.o cu_buildarea.o cu_clean.o cu_print.o cu_misc.o
 cu_ptarray.o cu_geodetic.o cu_geos.o cu_tree.o cu_measures.o cu_node.o
 cu_libgeom.o cu_split.o cu_stringbuffer.o cu_triangulate.o cu_homogenize.o
 cu_force_sfs.o cu_out_wkt.o cu_out_wkb.o cu_out_gml.o cu_out_kml.o
 cu_out_geojson.o cu_out_svg.o cu_surface.o cu_out_x3d.o cu_in_geojson.o
 cu_in_wkb.o cu_in_wkt.o cu_tester.o  ../liblwgeom.la -lcunit
 libtool: link: mpicc -g -O2 -Wall -Wmissing-prototypes
 -I/data/software/geos/3.4.2/include -I/data/software/proj/4.8.0/include -o
 .libs/cu_tester cu_algorithm.o cu_buildarea.o cu_clean.o cu_print.o
 cu_misc.o cu_ptarray.o cu_geodetic.o cu_geos.o cu_tree.o cu_measures.o
 cu_node.o cu_libgeom.o cu_split.o cu_stringbuffer.o cu_triangulate.o
 cu_homogenize.o cu_force_sfs.o cu_out_wkt.o cu_out_wkb.o cu_out_gml.o
 cu_out_kml.o cu_out_geojson.o cu_out_svg.o cu_surface.o cu_out_x3d.o
 cu_in_geojson.o cu_in_wkb.o cu_in_wkt.o cu_tester.o  ../.libs/liblwgeom.so
 -lcunit -pthread -Wl,-rpath -Wl,/usr/local/lib
 #mpicc -o cu_tester cu_algorithm.o cu_buildarea.o cu_clean.o cu_print.o
 cu_in_geojson.o cu_in_wkb.o cu_in_wkt.o cu_tester.o  ../.libs/liblwgeom.a
 -lm -lcunit -L/data/software/geos/3.4.2/lib -lgeos_c
 /data/software/src/postgis/postgis-2.1.3/liblwgeom/cunit/.libs/lt-
 cu_tester: /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.15' not found
 (required by /data/software/geos/3.4.2/lib/libgeos-3.4.2.so)
 make[2]: *** [check] Error 1
 make[2]: Leaving directory
 `/data/software/src/postgis/postgis-2.1.3/liblwgeom/cunit'
 make[1]: *** [check] Error 2
 make[1]: Leaving directory
 `/data/software/src/postgis/postgis-2.1.3/liblwgeom'
 make: *** [check] Error 1
 SciLinux 6.5
 This happens using both 2.1.3 and 2.2.0
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3067>
