[postgis-tickets] [PostGIS] #3067: Make check fails v 2.1.3
PostGIS trac at osgeo.org
Tue Mar 17 05:41:33 PDT 2015
  Reporter:  serbinsh  |       Owner:  pramsey
      Type:  defect    |      Status:  closed
  Priority:  high      |   Milestone:  PostGIS 2.1.6
 Component:  postgis   |     Version:  2.1.x
Resolution:  wontfix   |    Keywords:
Changes (by pramsey):
  * status:  new => closed
  * resolution:  => wontfix
Comment:
 The problem is not in PostGIS, it's in your build setup somewhere
  /usr/lib64/libstdc++.so.6: version `GLIBCXX_3.4.15' not found (required
 by /data/software/geos/3.4.2/lib/libgeos-3.4.2.so)
 make[2]: *** [check] Error 1
 or in your decision to deploy dependencies outside the system areas. Patch
 accepted if it's something you can tweak in the build system to support
 your case that doesn't break other systems.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3067#comment:1>
