[postgis-tickets] [PostGIS] #3065: Spatial index on LINESTRING not used under some circumstances
trac at osgeo.org
Mon Mar 2 14:27:53 PST 2015
Reporter: realityexists | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone:
Component: postgis | Version: 2.1.x
Keywords: |
Comment(by realityexists):
Thanks, I tested the 2.1 branch (r13295), now using PostgreSQL 9.2.6 on
Linux x86. I can confirm that the picksplit message is gone, but the index
is still not used. I got it down to a minimal repro. The tables are very
simple:
CREATE TABLE test_poly
ts_id integer,
border geography
CREATE TABLE test_line
segment_id integer,
timerange tsrange,
line geography,
segment_length integer
Query:
BEGIN; -- Problem doesn't happen outside of a transaction
DROP TABLE IF EXISTS _temp_line;
CREATE TEMP TABLE _temp_line AS
SELECT * FROM test_line;
-- Problem doesn't happen without this UPDATE.
-- Also doesn't happen without the seemingly-irrelevant timerange column.
UPDATE _temp_line SET segment_length = ST_Length(line);
CREATE INDEX ix__temp_line_line ON _temp_line USING GIST (line);
-- ANALYZE _sia_segment; -- This doesn't help!
EXPLAIN
SELECT ts_id, segment_id
FROM test_poly a
JOIN _temp_line s ON ST_Intersects(a.border, s.line)
-- ROLLBACK;
EXPLAIN output:
Nested Loop (cost=0.00..893167397.30 rows=1083307 width=8)
Join Filter: ((a.border && s.line) AND (_st_distance(a.border, s.line,
0::double precision, false) < 1e-05::double precision))
-> Seq Scan on test_poly a (cost=0.00..1363.05 rows=14805 width=880)
-> Materialize (cost=0.00..8264.72 rows=219515 width=36)
-> Seq Scan on _temp_line s (cost=0.00..5559.15 rows=219515
width=36)
But when running outside of a transaction or without the UPDATE statement
or without the timerange column:
Nested Loop (cost=0.00..116283.23 rows=1083307 width=8)
-> Index Scan using ix__temp_line_line on _temp_line s
(cost=0.00..7.69 rows=7 width=36)
Index Cond: (a.border && line)
Filter: (_st_distance(a.border, line, 0::double precision, false)
If you want the data I can upload that somewhere and send you the link.
It's ~10MB compressed.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3065#comment:3>
