[postgis-tickets] [PostGIS] #3031: "POINT EMPTY" as WKB defaults to "MULTIPOINT EMPTY" when restoring with copy and failing validation
trac at osgeo.org
Fri Mar 20 03:27:54 PDT 2015
Reporter: jeanchristophesaville | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.6
Component: postgis | Version: 2.1.x
Keywords: POINT EMPTY , MULTIPOINT EMPTY |
Comment(by strk):
Looking at the currently expected output, I see issues with both point and
multipoint.
A sane expectance, for a (polygon) typmoded geometry/geography,
is to accept only 2d polygons, of any srid:
polygon|0|Polygon|0|OK-BOK-GOK-BGOK
polygon|4326|Polygon|0|OK-BOK-GOK-BGOK
polygon||COUNT|4|
polygon||GCOUNT|4|
But we're also expecting (insanely, I'd say) that for a (multipoint)
to accept both 2d multipoints AND points:
multipoint|0|Point|0|OK-BOK-GOK-BGOK
multipoint|0|MultiPoint|0|OK-BOK-GOK-BGOK
multipoint|4326|Point|0|OK-BOK-GOK-BGOK
multipoint|4326|MultiPoint|0|OK-BOK-GOK-BGOK
multipoint||COUNT|8|
multipoint||GCOUNT|8|
And (again insanely) that for a (point) typmoded geometry/geography,
to accept NOTHING:
point||COUNT|0|
point||GCOUNT|0|
By "accept" here we mean by stepping trough WKB.
The wrong failures in the point case are due to WKB converting the point
into a multipoint.
The wrong successes I'm not sure about (why is a point accepted in a
multipoint?)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3031#comment:23>
