[postgis-tickets] [PostGIS] #3031: "POINT EMPTY" as WKB defaults to "MULTIPOINT EMPTY" when restoring with copy and failing validation
trac at osgeo.org
Fri Mar 20 03:42:32 PDT 2015
Reporter: jeanchristophesaville | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.6
Component: postgis | Version: 2.1.x
Keywords: POINT EMPTY , MULTIPOINT EMPTY |
Comment(by strk):
Oh, now I got why for a multipoint we accept both multipoint and point. It
is because the _value_ of POINT EMPTY becomes a multipoint and is thus
accepted. So it's still the same exact problem we're trying to address.
So, with the workaround fix in place, we should be accepting both points
and multipoints (we only test empties) for the point case and we'd be
still accepting both points and multipoints (empty) for the multipoint
case. Basically it would be making the point typmod as "tolerant" as the
multipoint one (when it comes to empties).
The test should probably be further enhanced to also test non-empties...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3031#comment:24>
