[postgis-tickets] [PostGIS] #3056: Confusing results from ST_3DDistance
trac at osgeo.org
Fri Mar 20 07:36:34 PDT 2015
Reporter: strk | Owner: pramsey
Type: defect | Status: reopened
Priority: medium | Milestone: PostGIS 2.1.6
Component: postgis | Version: 2.1.x
Resolution: | Keywords:
Changes (by strk):
* status: closed => reopened
* resolution: fixed =>
Comment:
sfcgal tests are failing:
--- sfcgal/measures_expected 2015-01-21 14:11:41.220795343 +0100
+++ /tmp/pgis_reg/test_1_out 2015-03-20 15:32:27.583928175 +0100
@@ -31,10 +31,13 @@
distancepoly6|0|32.5269119345812|LINESTRING(2 2,2 2)|LINESTRING(2 2,2
2)|LINESTRING(2 2,25 25)|LINESTRING(25 25,2 2)
3dDistancetest1|6.40312423743285|6.40312423743285|f|f|LINESTRING(1 1 1,3
2 7)|POINT(1 1 1)|LINESTRING(1 1 1,3 2 7)
3dDistancetest2|0|1.73205080756888|t|t|LINESTRING(1 1 1,1 1 1)|POINT(1 1
1)|LINESTRING(1 1 1,0 0 0)
-3dDistancetest3|4.09994192757944|6.48074069840786|t|f|LINESTRING(1 1
1,0.61904761904762 -0.19047619047619 4.90476190476191)|POINT(1 1
1)|LINESTRING(1 1 1,5 2 6)
-3dDistancetest4|2|10.0498756211209|t|f|LINESTRING(1 1 3,1 1 1)|POINT(1 1
3)|LINESTRING(5 7 8,1 1 1)
-3dDistancetest5|2|10|t|f|LINESTRING(5 0 5,5 2 5)|POINT(5 0
5)|LINESTRING(11 0 5,5 0 13)
-3dDistancetest6|0
+3dDistancetest3|0.894427190999916|6.48074069840786|t|f|LINESTRING(1 1
+3dDistancetest4|0|10.0498756211209|t|f|LINESTRING(1 1 3,1 1 1)|POINT(1 1
+3dDistancetest5|0|10|t|f|LINESTRING(5 0 5,5 2 5)|POINT(5 0
+NOTICE: During distance(A,B) :
+NOTICE: with A: LINESTRING(1/1 1/1 1/1,2/1 2/1 2/1)
+NOTICE: and B: POLYGON((0/1 0/1 0/1,2/1 2/1 2/1,3/1 3/1 0/1,0/1 0/1
0/1))
+ERROR: Polygon is invalid : ring 0 self intersects : POLYGON((0/1
0/1,2/1 2/1,3/1 3/1,0/1 0/1))
emptyPolyArea|0
emptyLineArea|0
emptyPointArea|0
--- sfcgal/tickets_expected 2015-03-06 09:55:39.138987646 +0100
+++ /tmp/pgis_reg/test_9_out 2015-03-20 15:33:31.992180051 +0100
@@ -233,7 +233,7 @@
#2048|2|t|t
#2048|3|f|f
#2112a|0|LINESTRING(2.5 2.5 1,2.5 2.5 1)
-#2112b|1|LINESTRING(1 1 1,1 0 1)
+#2112b|0|LINESTRING(1 1 1,1 0 1)
#2108|SRID=3395;POINTM EMPTY
#2117|SRID=3395;POINTM EMPTY
#2110.1|f
Ticket URL: <http://trac.osgeo.org/postgis/ticket/3056#comment:5>
